Discuss Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
I think that termination technique is at least as important as torque.
For example, I have been in the habit of 'untwisting' the strands of some larger cables (tails) when terminating as I reasoned that the strands could then move freely to take up a minimum space in the terminal and be less prone to loosening.
There was a report about this a couple of years ago:
http://www.electricalsafetyfirst.org.uk/mediafile/100015987/Switched-On-24.pdf
See pages 14 and 15.
The original experimental report is here:
http://www.electricalsafetyfirst.org.uk/mediafile/100013801/Meter-Tail-Investigation-Report.pdf
I think that untwisting rather than 'flattening' is what matters. The group of strands will take up the shape of the terminal when tightened.
The technique is probably not of any use for small cables with fine strands in some large direct screw terminals, as the strands will just displace up the sides of the screw.
to be fair on tri-rated etc we would just use ferrules.
personally i would always use ferrules on stranded unless its a cage clamp type termination
Unless torquing to a high setting with a T-bar or similar or torquing to a low level to prevent shearing I find little use for a torque screwdriver. I've always found torqueing to 'hand tight' to be pretty useless as this is easily judged by feel.
I have that one. Personally I don't go with the settings that the manufacturers say because for example if you tighten a screw up on the earth or neutral bar, say it's on 1.0mm cable then it just breaks the conductor so how are you supposed to do it eh. I personally think you are better using your own judgement, like I say if you do as per the manufacturers instructions it with break the conductors.
Work issued me one and it's handy to have. It saves you wrenching the mcbs and causing them damage and it also saves fatigue on your hands by needlessly over tightening. The kits really good and easy to setup. Just watch 1mm connection as they might snap due to torque setting.
Reply to Anyone got Wiha Torque screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
Hi Chaps I've got a Wiha torque driver but only came with couple of bits (below)... none of which fit 'outgoing side' of Contactum RCBO's...
Well i brought a set because i needed this MOD1 &2 (wouldnt mind but the shops didnt even know what i was talking about) S1&PH !! well ANYway i...
Long time no see and I hope you're all doing well. I see that torque screwdrivers have become the height of fashion in the UK over the last...
9K
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
I have had mine about 3 years ( maybe longer ) and have never bothered to have it reset Does anyone or has anyone bothered to have their vde...
