Discuss Arc Fault Detection going global ... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That does surprise me. For a 500wt load to take that degree of inrush current. Is there any possibility there may be some small transformers built in to the appliances you are or using? (or low voltage lighting on the old wire wound trafo, s)
You lost me a little with that post. AFCI, s were created to detect arcing? No?Thats exactly why AFCIs were created. After it was theorized that 75 amps could be seen at the end of a really long run a 75 amp pickup breaker was created as a concept but soon realization came that certain goods would trip it.
Oh, that's all right then, because common sense always does prevail whenever they get into law-of-diminishing-returns territory, and they always carry out comprehensive cost-benefit analyses....They are trying to bring it in, but when common sense prevails, they'll either reject, or make sure the they are not cost prohibitive
[Makes mental note to finish watching David Savery's rant..]
You kidding? The trojan horse emptied its contents:
I'd recommend wathcing the video...
Reply to Arc Fault Detection going global ... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
