Discuss Assignment guide in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
J
jonboy11
Hi, i am really struggling to find the relevant books and guidance notes to complete my assignment at Level 3 - 2365. Can anyone please help.
i am doing the assignments 2365-303, 2365-304 and 2365-305 which i am doing ok i think but i am struggling for answers on some points and would be grateful if someone could help me with the questions and explain them to me so i can progress... i will write the questions down and see what people say and hopefully i can learn at the same time.... And just before anyone says anything i have grafted on this and i am looking for help not someone to do my coursework...
2365-303
6b describe the following symptons, the most likely electrical fault for - the outside lights above the entrance only turn off when the protective device is turned off???
8a and 8b describe the most likely faults to occur in
terminations and connections
and
instrumentation and metering at the intake position
9cdef
a number of areas within the nursery require special precautions to be taken during fault finding, identify these precautions in relations to the following
c fibre-optic cabling
d electronic devices
e it equipment
f high frequence or capacitive circuits
11. a maintenance report details a number of situations. identify and explain suitable tests to determine the likely problem for each of the following situations
a. the lighting circuit was still live although the protective device had operated
b. a new machine does not function
c. a new three-phase motor is running the wrong way.
jonboy, some of those are plain common sense. suggest you put what you think as answers, then you will get some help.
I know but I am worried that they are to simple for the assignment,
Here's the answers I think
6b faulty appliance
8a
8b confused with question
9c fibre optics precautions - correct training, specialist training, right equipment
9d electronic devices - pat tested, correct equipment, suitable training
9e it equipment - pat tested, correct operator, network criteria there in
9f unsure
11a neutral fault and test
11 b test machine, test power, test supply
11c test machine, speak to operator, check certificates,
Like I said I want help not them answering
6b. lights only turn off when mcb is switched. try light switch shorted out.
6b describe the following symptoms the most likely electrical fault for - the outside lights above the entrance only turn off when the protective device is turned off??? answered by Tel
terminations and connections where you join two cables together or connect a cable to an accessory since you are doing the connecting what may not actually happen?
and
At the intake you may be monitoring current, power, voltage, cost etc. the equipment is most likely to need to carry high currents as it is at the intake, or be sensitive electronic equipment. so what may fail?
9cdef
This is asking for special precautions so
c fibre-optic cabling What are the specific risks of having a cable with a powerful focused light source inside it?
d electronic devices When you have electronic devices which tests can cause problems or false readings?
e it equipment Which fault finding tests can cause damage to this equipment?
f high frequency or capacitive circuits What are the capabilities and vulnerabilities of your test instruments for these circuits?
can't really summarise a guide here so
a. the lighting circuit was still live although the protective device had operated fused neutral not line how would you test for this?
b. a new machine does not function is there power to the machine, if so then faulty machine, if not then how would you check where the disconnection was?
c. is reversed phases so how would you test phase rotation and comparison to what the motor is requires?.
Hi, I'm new here and currently answering the question relating to the outside light.
Could it not simply be a case of a faulty switching mechanism in the switch. If there was a short wouldn't the MCB trip when it was on, resulting in the light not working?
Reply to Assignment guide in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Good morning all I have a summer assignment that I need to have ready before the 4th of September and I have 4 tasks that I have yet to complete...
Guidance please - C&G L3 electrical installation - Hotel extension project Hi folks, I am fairly new to this forum but it looks like the...
Hi Guys I am currently on the NVQ 2357 on my way for the AM2 and get fully qualified, at the moment i am doing private jobs, on the NVQ 2357 they...
Hi As some of you will know . I'm studying level 2. I have the onsite guide. But does anyone know any books I can buy to help me understand...
