Discuss Best practices electrical maintenance in the UK Electrical Forum area at ElectriciansForums.net
Two questions regarding best practices.
First one I don’t know if I’m being OTT but would you lock off a tripping circuit if you cannot investigate at that time?
The second is regarding maintenance and removal of motors. If the motors been removed and awaiting a replacement what would you say is best practice for terminating the exposed connections. I used to terminate in an appropriate JB and drop the tails out at the local isolator but then realised I don’t always have a JB available 😂😅
Thanks guys as always for your kind replies
First question, definatly label as faulty, locking as well is good practice.
Second question, Definatly lock off and label, then either terminate or as Brian says, short.
is there any info in the company handbook or documented procedures?
Reply to Best practices electrical maintenance in the UK Electrical Forum area at ElectriciansForums.net
I know I’m very health and safety conscious and electrical safety has always got me thinking with various sparks saying different things in...
Evening all. I have a question as I can’t get my head around something with solar PV I’m going to be working on a new build in a couple of...
I found myself needing to do some emergency plumbing at home this evening. I've got a small guest flat on my property which has been empty for...
Hi, I have just retrieved a Federal Electric TB63SNT Switch/Fuse unit from a skip, it looks to be in very clean condition no rust or damage to...
Hi guys I wanted abit of advice on the best way to electrically isolate a supply when you don’t have the correct lock offs for the device i.e...
