got a job starting next week
5 flats within a old house
each flat has there own water and gas incoming feed
-I remember seeing blue plastic pipe for each flat then copper after stopcock
-I know technically I don't need to bond the water- but would you bond each in 10mm at the stop cock (ground floor communal cupboard- or 10mm from the c/u within the flat to point of entry of service into the flat itself?
not sure of gas income was plasdtic or not yet- will have to check this out
