Discuss Builder work misinterpretation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
fedail
Hello,
Could you please clarify what is the difference between this terminologies
Reservation , penetration , Opening wall
those we are use them with pipes sleeves and cable trays work inside the wall .
thanks
think it may be something to do with penetrating, making openings in walls, reinstating fire barriers. hope you realised my last post was a joke. :smug:
:) thanks anyway.
I knew that all of those are Opening in the wall . what i want to know what is the differences between them
Reply to Builder work misinterpretation in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hello, we moved in to a new build flat a couple of years ago and after a year or so we realised that the landlords electric meter had run up quite...
Hi all. I'm currently building an island in my kitchen which will contain a gas hob. I've cut a trench about 60mm wide from the edge wall to...
We have had builders in, who have stopped for Xmas. My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I...
