Discuss Can i connect a relay to a jump start terminal. in the Auto Electrician Forum area at ElectriciansForums.net
Edgar1989
I am trying to add additional exterior lights to me car.
The battery is located to the rear of the car, rather than trailing wires right through the car. Can I wire the relay into the jump start terminals that are present in the engine bay? Would this still provide power for this?
Depends upon the vehicle, but usually yes. Normally the "jump start" terminals are present in the engine bay simply to facilitate jump starting as the battery is buried in the boot...actually a good configuration IMHO, as the battery stays cool, and is protected from the weather, splashing, salt etc.
Thus, the 2 terminals in the engine bay are "live" all the time, so you can take a feed from there. However...they may also be connected all the time, even when the ignition is off, so you are basically running your new circuit directly off the battery. This may mean that any auto shut-down circuitry if the battery gets low, will not work. If the engine bay terminals are disconnected when the ignition is off, it's ok for an added circuit, but if not, you have to be aware that your new lighting, if left on, could drain the battery, so it would be best to power the new circuit from those terminals, but break the feed through the ignition switch.
There are other ways of feeding extra cicuits, and you may have spare outputs available in the fuse box, so i would check that out first.
Important - remember appropriate fusing!
Reply to Can i connect a relay to a jump start terminal. in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
Hi all. I'm trying to put a light-bar on my (facelifted) Land Rover Freelander 2. I'm wanting to wire it so the light-bar will be energised when I...
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
Hello! I'm needing some help. I'm wiring in a start panel, using a spst toggle, and a (momentary?) push button. The idea is to flip the switch to...
