Discuss Ceiling rose in the DIY Electrical Advice area at ElectriciansForums.net
Good evening all I'd be so grateful for some help. I used to be an electrician years ago but I am no longer and just have a question I'm unsure of.
I live in a new build and I have a ceiling rose in the garage and my wife asked me to put 2 tiny 6watt led lights either side of the garage door. I've had a look in the ceiling rose and it's full. Each loop has been used am I ok to add another, to feed each light? I'm sure I am but just thought I'd double check with you guys. Thanks so much for the help I really appreciate it. God bless.
Standard ceiling rose, with 3 sets of terminals?
Switch live, and neutral feeding the pendant flex, and the permanent live in the middle? That’s the tingly one! Power off, but you’ll know that already.
Yes it’s fine to connect these lights as long as they are rated for mains voltage.
Surprised you’re asking to be honest, if you have been an electrician in the past.
Yes I thought I'd be ok just when you've not been in the game for so long you lose confidence. Appreciate the help. Thank you.
Reply to Ceiling rose in the DIY Electrical Advice area at ElectriciansForums.net
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
A rose in my 1970s kitchen ceiling became loose (one fixing screw had been inserted right on the edge of the hole in the ceiling) and when I...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
