Discuss commercial testing in the UK Electrical Forum area at ElectriciansForums.net
Fire alarm supply is fine. No code
why would you?...james_t87 so if 1.5 was connected to a 13amp fused spur from a ring final with a 32amp mcb you would not code that.
Do you hold 2391 or equivalent?
Maybe stick to domestic then? Competence and experience go hand in hand IMHO. As an example; you could be the best domestic spark in the world but if you've never worked on three phase, how could you deem yourself competent to do so? Similarly, if you are only used to testing domestic, there's nothing to say you're not competent to do so, but when you start asking questions like "Do the same regs apply in commercial installations?" you unfortunately open yourself up for people to question your competence to carry out work on commercial installations.
It is perfectly acceptable to install 230V ventilation equipment in zone one providing it is IPX4 and meets all other requirements of BS7671. Pre 17th ed that would mean no 30mA RCD protection would have been required. (I'm assuming the install is pre 17th ed.)
When reading the onsite guide recently I noticed...
I don't have my own BGB so can't check. I have however always gone on the ipx4 rule. Cheers.
Reply to commercial testing in the UK Electrical Forum area at ElectriciansForums.net
