T
TPES
Me and a friend were discussing down lights in bathrooms and what’s required, both had different opinions.
2.25m from floor level is outside all zones right.. I've found this accounts for most bathrooms, Still IP65 Down lights installed above a bath, as sprays from water jets (the shower) which is what i do.
Past the bath (Zone2), If ceiling height was still in zone 2 then IPX4 down lights to be used.
But as its not and above 2.25m from floor level meaning outside zones, are the regs stating Any Down light is acceptable? Still common sense tells me that i would want a certain degree of protection from the damp/moisture in the air,
What IP Rated down lights are you installing outside the bath area?
Covering your backside and just going for IP65 all round? as i know some sparks do?
