Discuss Contactor that heats up in the DIY Electrical Advice area at ElectriciansForums.net
cobrax2
Hi guys
I bought an Hager Esc463s contactor, that seems to me it heats up too much? Under no load, just connecting the coil, it heats up to about 50 Celsius, ambient temperature 30 Celsius. Is this normal? Do the contactor coils heat up that much? It is not defective, as i sent it back, and bought another one, the same model from another place, same temperatures!
Thank you!
Contactors work by sending current through a coil, creating magnetism, that pulls the switch in.
There will be some heat generated.
Does the contractor have enough free air around it to dissipate heat?
It may be in beside other devices, or enclosed where heat can’t readily escape.
What voltage is at the coil terminals.
Have you actually measured that.
A coil of a contactor will generate heat I would email Hager and ask them directly.
Reply to Contactor that heats up in the DIY Electrical Advice area at ElectriciansForums.net
Calculate the temperature rise in a system consisting of six conductors carrying 1500 amperes each at 132kV, insulated with XLPE, and spanning a...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
m having a bit of an issue that is proving difficult to resolve. For 2 years I have been having no problems with my setup. I have a 3 zone house...
