dinkidow
what size contactor (delta) do i need to run a 15kw 3 phase motor 24 v coil pls
Discuss contactor in the UK Electrical Forum area at ElectriciansForums.net
This is an existing circuit with 3 contactors to start and run the motor (soft start). The delta contactor has burnt out (AC3 10 Amp) therefore my calculations for a 15 Kw motor suggest the contactor is operating at its maximum and as it has burnt out before (im being told) I will suggest a higher rated AC3 contactor. The question was initially submitted to just see if any other person had come across these conditions. CheersNot quite understanding your question. Is this a new circuit? Are you after a contactor for a DOL starter or something?
Reply to contactor in the UK Electrical Forum area at ElectriciansForums.net
