Discuss Cooker supply 12kw correct cable size in the UK Electrical Forum area at ElectriciansForums.net
i bought a coffeee machine. it's a 3kW de longhi kettle. £2 from the charity shop.
Reply to Cooker supply 12kw correct cable size in the UK Electrical Forum area at ElectriciansForums.net
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind...
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
