M
m1ck_b87
Hi all
Which fuse am I most likely to come across on a domestic property cut out fuse 1361 or 88
I understand that an 88 comes with bolt holes or clips and 1361 is a bigger version of a 1362 fuse
Concur with GS... Loads of 1361's about. I dont often see 88's...not sure what you mean re bolts... 1361's are indeed like super-sized 1362's....OR at least that is what I have been told as I would never, I repeat NEVER, pull a main fuse...... Much more preferable waiting for DNO to turn up and pull it, that way you can waste a couple of hours waiting for them....which I really appreciate as I am self employed and love to idly sit around because other peeps do not possess either a watch nor an A-Z....
Put UNKNOWN in supply characteristics box if not written on fuse carrier.
cut out fuses
m1ck_b87,
NDG Elecs,
