Discuss Do I need conduit? in the UK Electrical Forum area at ElectriciansForums.net
S
Stan McArdle
Im considering my options for fitting an outside socket for the garden.
If I was to take a spur from a socket on the inside wall and drill through, would the 2.5mm Twin and E cable between the two sockets need to be fed through conduit or trunking? Or can I simply run it through the wall?
As above but a short stab of conduit takes away the chance of cable damage from any sharp points on the bricks.
What about protection from the vicious rodents and lost hamsters that hide in the wall cavity? (Now that's another story!) ;-)
Not a requirement of the regs. Daz
I think I've asked this before but why do you call every single member Daz :confused:
It would be nice if you could make the effort to try and remember a few of our names. :)
My memory has become full over the years and so I can only remember one name now. Unfortunately it is my own. Luckily every so often I meet another 'Daz' so it becomes appropriate.
I shall desist from ending my posts with my name if you prefer. Daz (woops)
I'd slide a section of conduit in the hole. Partly its easier to get the cable through as they can't get into the gap. Second reduces the risk of any building work higher up causing debris to fall and damage cables.
No keep using it. Daz;)
Personally I would conduit it through to the outside socket, keeps out little critters and any possible condensation, although there is usually vent for that at bottom of socket.
Could be wrong, something I heard, was told that if the wall is of a certain depth it should be tubed, probably nonsense. Daz
And I imagine you'd have to drill a 20mm hole right through to accommodate conduit, a bit OTT for 18 inches of 2.5mm cable, and generally you'd bash out a rear knockout in the existing inside socket back box so it's easier to use a smaller diameter masonry bit and avoid messing up the backbox. Always go slightly downhill from inside to out too and try to drill the very last bit without hammer action to avoid a huge lump of masonry falling off on the outside. ;)
Reply to Do I need conduit? in the UK Electrical Forum area at ElectriciansForums.net
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Doing some work in a commercial restaurant/kitchen the builders had already boarded and plastered the walls meaning my only viable route is to use...
