Yes, you have a good point there!The Hager meters are around 3 times the price of a standard meter.
Yes. Why I was called!For a kitchen circuit? toaster and kettle.... pop!
Just shows that wylex breakers do NOT fit an MK board
That's assuming they knew such a thing was available. I've come across a few sparkys who have no idea what's available - and won't enquire. One example :But equally it seems strange to have dangling Henleys and the external meter when they could have got the meter kit for the Hager board...
I like the way they carefully notched the plastic to achieve a perfect fit ...Yes. Why I was called!
PTFE......plumbers tape for everythingIs the thread wrapped in ptfe tape to make it fit tighter?!
Met a few like that brilliant at what they could do, but when you need to think outside the box a bit to find solution absolutely pants.TBH, his workmanship was top notch, he was just an idiot who didn't understand how sectioned trunking works or what's available.
Good haul, remind me not to visit.some diy disasters for your viewing pleasure.View attachment 63983
This one is from a factory how many bodges!
Mm earth not long enough then!
Yes that is 1.5mm t&e into .75mm flex from a 30a ring final?
Same again mix of .75 and 1mm flex feeding multiple socket outlets all off 3036 30a fuse!
Pond spaghetti anyone, all outside in a dripping wet brick pillar no rcd all in 1.5 t&e no earth connected and the black flex was cut off in the garden still live inches from metal railings around the pond. Lethal! All this was also from 3036 30a fuse. Not any more all removed!
Sy
Ohh dear, time for a rewire then.
bit of
The electrical equivalent of "Its just a flesh wound"?bit ofsleevingtape on that will be fine.
yeah, it's only 2 arms.The electrical equivalent of "Its just a flesh wound"?
