Also noted while I was there that the extract fan has no ducting to the exterior at all and instead vents through a 4 inch wall straight into the staff kitchenette via a shutter! There's a list of other electrical and building work horrors that the builder has done on behalf of the new tenants. It beggars belief what some people will accept and pay for.
Another little one from me (but worth a mention). Old lamp column. BS1361 fuse clearly failed / lost an end cap at some point. Fuse wire wrapped around the old one.(NB I did replace with the correct fuse)
Don't know what's worse, the missing cover on the esco, the link between neutral and earth after the meter or the fact that someone has managed to install a new board whilst this still exists and didn't even bother with a glam for the tails.
I have probably got in stock a replacement fuse carrier for that.
send me the dimensions and I will check.
will cost you a beer to cover the postage.
In a HMO somebody has been very creative with bypassing the meter, so they unscrewed the neutral in the incomer covered it in tape then shoved it back in, used the earth as the neutral as its a pme system, completely butchering the cu in the process.
Oh I see now, operating the MCB enables/disables the meter. I didn't realise the busbar wasn't into the breaker with the earth wire. Hope they have been reported...
