Discuss Downlights + loft braces in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rs250250
Hi All,
I am currently doing a large rewire, and one of the issues that has cropped up is downlights in the flat roof loft conversion.
Good practice states that a loft brace should be used to allow good air circulation above and around the down light, and to allow thermal bridging by laying insulation above the downlight.
They are using kingspan/insulation boards on the flat part of the dormers. How would you guys get round not having to cut out large parts of the insulation board to allow the down lights to be fitted.
Can normal insulation be fitted in place of the kingspan?
Change the kingspan for the equivalent in foil insulation. I do'nt think building control will like you cuting the kingspan.
Reply to Downlights + loft braces in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi My 4 bed 2 storey house was extended 2 years ago and completely re-wired, but I am having to upgrade the insulation and board out the loft...
I am having a flat roof constructed with solar panels over. As it is a cold, vented flat roof I will be having 175mm of Cellotex insulation...
Hello folks, Just looking for a little guidance please. I am sure that this is something that many of you have come across before. I am...
