Discuss Downstream db in the UK Electrical Forum area at ElectriciansForums.net
Iona222
Trainee
I've got my 2391-52, but I've never tested a board downstream, its a db for an extension, there's no rcd on 1 lighting and 1 ring.
Is it ok just to change the mcb to a rcbo.
I remember wheni did the course they mentioned selectivity/discrimination
Regards
The main switch on the board is a rcd switch.
Don't know which board you mean has rcd main switch, but surely in either case that means the lighting circuit and rfc are RCD protected after all?
Stick a photo of each board up if there is still confusion.
The main board has a rcd switch. Ye so I would say, they are protected.
Reply to Downstream db in the UK Electrical Forum area at ElectriciansForums.net
I was wondering if someone might be able to help either confirm or change my understanding on the use of S-Type RCDs. I believe that they can be...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
