Discuss DS3 Brake light fault in the Auto Electrician Forum area at ElectriciansForums.net
Hi guys,
Got a Citroen DS3 with a rather strange fault. The tail light brake lights (Left and right) never work with the brake pedal, however the actual bulbs are fine because they light up when the lights are switched on (but the brake light always stay on). Checked the brake switch and it meters fine and the strange thing is the centre light on the rear glass works with the pedal as expected.
So the bulbs work, the brake switch works, fuses are fine and wiring to the brake bulbs must be fine because they do work only with the lights switched on.
Any ideas please? Any input would be appreciated as I'm baffled! Cheers
auto wiring has never been a strong point with the froggies. ( sorry, not very helpful ).
sounds as though been supplied from light circuit, but that would not explain the supplementary light working normally. time to start tracing the wiring back from the brake lights to switch then further back.
I can't even find a wiring diagram anywhere. Is there a chance that the stalk control itself could be faulty?
The usual culprit is the harness trapped and shorted where it comes through the tailgate , if it has one. Another culprit is the lamp holders , especially on dual filament holders where they make contact with both filaments cause by being incorrectly fitted or wrong lamps, or just plain worn out. I would check the harness first though , and check for water ingress and corrosion.
Is there a lighting control module? Maybe this has separate outputs for each lamp?
Reply to DS3 Brake light fault in the Auto Electrician Forum area at ElectriciansForums.net
Hi I have a 2014 mazda bt50 and I'm having trouble woth my tail lights. On one side the tail light and indicator doesn't work but the brake light...
Hello all, I have a tail light for a '12 Ducati Panigale 1199 S, that I can't get working properly. The brake light / daytime running lights...
Hello. My son purchased these new led flicker brake light bulbs for his ute (they flash for 3 seconds then go solid). They work fine with engine...
The brake lights on my caravan (Sprite Swing) are not working, but all other lights work. I have tested the globes and both elements are working...
Hello, I've installed a Monsoon Extractor Fan kit today, all is up and running and everything is working with the exception of the LED. When I...
