Discuss earthing system? in the UK Electrical Forum area at ElectriciansForums.net
mgzr
having a slight disagreement with a maintenance guy on a job im testing...
just a bit of banter, but can any confirm this earthing system..?!
if PEFC = PSCC, it's TNC-S.
it's a funny arrangement. 4 black fuse carriers and 1 white one. is that PC idea of racial equality?
Reply to earthing system? in the UK Electrical Forum area at ElectriciansForums.net
Hi. The question is..... can saturated ground affect earth resistivity testing equipment? Some days there's an unacceptable earth reading, another...
Carrying out a EICR in a commercial setting. In the main intake room the DNO supply comes in and it states clearly this is a PME system. 5 years...
Went to a house to extend a circuit and upon doing the minor works I couldn't figure the earthing system. There was no DNO cutout and L and N came...
Apartment complex lights not working or pool pump system. Novice maintenance man with very little experience in electrical, and my job is on the line
