Discuss Eaton Breaker Date Code in the The Welcome Forum area at ElectriciansForums.net
Bob
I am trying to determine the date of manufacture of the subject breaker. Can anyone help me with that. I am not sure if the date code is shown. The face of the Eaton breaker has the following:
Eaton
Type BR260
Type C260
120/240 V -
Cu/Al
HACR Type
2 Pole J969
E7819 - T
LR43556 Disj
A guess would be 1978 week 19. Thanks for any guidance.
QZk6T5
from eaton MCCB data sheet:
Date Code The Date Code is applied at the time of final manufacture. The date code is in the format YYMMDD and may include a suffix which identifies the plant o.....
MCB may be as you say. also earlier versions might not correspond to current data sheets.
Reply to Eaton Breaker Date Code in the The Welcome Forum area at ElectriciansForums.net
I thought that I posted this in the DIY part of the forum but I believe I did not. I am sorry about that. I put in a 10' x 20' metal shed about...
I am trying to determine the date of manufacture of the subject breaker. Can anyone help me with that. I am not sure if the date code is shown...
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
77K
