Discuss Electic Shower in the Australia area at ElectriciansForums.net
Check your connections at shower and isolator. It's possibly a bad connection or a cable not stripped back properly and tightened down onto the insulation. Have you tested the circuit R1 + R2 etc?
If RCD/MCB is ok water pressure is ok connections ok only thing really to do is get an electrician in to test properly it may be that the fault with the old shower wasnt a fault at all but you may have problems elsewhere that is causing both showers to misbehave.
Chris
The purge pin is only on their digital remote triton showers sorry . It may be a water pressure problem. If in doubt call in someone or call triton and ask their technical department.
Thanks for you assistance i did call trition and they asked me to check the voltage, did not seem to helpful not sure if it is water pressure as the presure light is not on
Thanks again
Did they let you know what the call out fee is? it may be more cost effective to get someone in to confirm it's the shower then call triton in for free?
Reply to Electic Shower in the Australia area at ElectriciansForums.net
Hi everyone My mira power electric shower is not doing anything when i press the power button. There is no led lights to check on the unit to...
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
GFCI green light is lit when not under power draw. The bidet seat functioning causes light to pulse yellow (and creates a pulsing and knocking...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
