C
Clint Gaskell
Here's the problem if anyone can help.
Currently have gas hob and separate gas oven. Coming from the cooker isolation switch on the wall and fed down a cavity to below the kick boards is a heavy duty 3 core 13 amp feed with a 4 socket metal extension which I think is fused, this supplies cooker hood fan, hood light and ignition on hob using 3 separate 13 amp plugs.
I now want to replace the gas oven with electric which means I have to disconnect the extension from cooker isolater in order to wire the cooker, without installing new 13 amp isolater switch, is there anyway of piggy backing these 3 devices to run off the cooker circuit?
Ive no other way of connecting hood fan, light and hob ignition without ripping the wall apart to install a new isolater switch.
