Thoughts please.
Hi I have a friend with a gremlin in her living room area of her house.
Problem
Her living room light slow dims by it self after a while of being on, no dimmer normal switch. Not always the same duration of being on.
Background
Last summer I repaired her living room light as it was a transformer based pendent. That slowly dimmed by it self after being on for awhile. However it did not do it at the same time every time, so I thought it's just a transformer problem so change the transformer. A few months after that it stared doing the same thing, oh I thought as it was a new transformer. So that got changed for a standard pendent, Bayonet fitting, as she wanted to change the light anyway. All was good.
Now last night she said that that light is now doing the same thing slow dimming. She does not appear to any other electrical problems in the house that she's seen, nothing trips nothing being erratic all the other lights in the house are just fine. Other then in her bed room which is above the living room she has been though three socket powered alarm clocks.
The kitchen light is a strip light. The rest of the lights are I think pendants. The CU is about 6/7years old. It's a two bedroom semi. Standard living room dimming room kitchen on ground floor. Upstairs two bedroom and a bathroom. The light is about 5/6 meters from the CU.
I have not done any test if not looked in to it yet. I have asked her to write done when it happens.
What do you think.
Problem
Background
What do you think.
