Discuss En suite extractor fan with run on timer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
hi, can't suss this, doing an extractor with run on timer, which has led light. Cabled the separate isolation switch, two way to fan, 2 way to jb, light switch l1 to isolator l1 at jb, sperate line feeds to lights, common to line at jb with live feed from lighting ring, neutral has neutral in and and out for lighting circuit, 2 lights out, neutral from isolator in. Test it and nothing on switching on, there is power in ok but both lights out and fan, nothing, can't see anything wrong with wiring, any suggestions other than give up and go for a pint!
Sorry if I'm reading your post wrong but all you need is a 3 core / earth from the main light to the isolator, then 3 core / earth from isolator to fan.
From light: Neutral to N in. Switched Live to L1 in.
Permanent Live to L2 in.
To fan: N out to N of fan. L1 out to switched L on fan.
L2 out to permanent L on fan.
Earths obviously to respective terminals.
Apologies if that's not what you wanted but your post is a bit confusing.
Hi that's what I've got, but not working?
Hi Paddington: Go back to basics mate, get the lighting working properly first then look at the fan problem.
You'll probably kick yourself when you find you've got so bogged down in it, you've missed something daft :oops::D.
Gotta go, back in an hour or so.
Westward, behave. No more dizzy electricity :p:D
Reply to En suite extractor fan with run on timer in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hey all, This weekend we are discounting a range of bathroom & extractor fans. All of these products are currently in stock for fast delivery...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
