Search the forum,
Discuss Extractor fan low buzzing in the UK Electrical Forum area at ElectriciansForums.net
Jess5112
Hi there
Not sure I am posting in the right place so apologies, you were all so helpful with a question I had last year so hope you can help with this one too! :)
There is an extractor fan in the bathroom which comes on when the light is switched on. When the light is switched off the fan stops running a few seconds later. However when the fan is off, it is still omitting a low buzzing, almost sounds like it’s still operating/trying to start up/sounds a bit like it’s taking off tbh but the sound is very low (much lower than when it’s on).
What could be causing this? Not sure if it’s signalling a fault/dangerous.
Any thoughts appreciated. Thank you so much :)
J
could be wind blowing in from outside.
Some are designed to remain on low until the humidity is low enough.
What is the make and model?
Reply to Extractor fan low buzzing in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hi all, I'm in the UK and have recently had a ducted extractor fan Mixflo 200W with timer fitted. The fan comes on with the pull cord and runs for...
