Discuss Fault with AEG oven/hob in the Electrical Appliances Forum area at ElectriciansForums.net
Stapes
Gents, I wonder if I could get your advice...
I live in a five year old block of apartments and all of a sudden a few days ago, the in-built AEG Complement oven stopped working (i.e., no power was being supplied to it as indicated by the lack of digital clock). At the same time, the separate electric hob (affixed to the granite above the oven) also stopped working. I could be wrong but I would have thought that these two items are not directly connected?
The electricity that supplies the rest of the flat is working perfectly, and no switches have tripped in the fuse box, nor anywhere accessible at the wall. Any ideas as to what i can do?
Many thanks in advance!
They are identified on the fuseboard as 'Cooker/Hob'. I didn't knowingly nudge anything as it was working one evening then it wasn't the following morning. Is this something that a professional needs to look into? If so, do you know of any websites that can help me find a trusted electrician local to Battersea?
In that case then yes i know where it is (alongside switches for the extractor, dishwasher, etc) and no it hasn't been switched off!
Reply to Fault with AEG oven/hob in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi Our oven stopped working suddenly including the clock. It was on the fan oven setting at about 150 degrees. I checked the fuse board - it had...
A friend's partner has an interesting fault, if it is a fault. She sets the shut down timer on the cooker and when the timer goes off (which in...
Hi all, Was wondering if anyone has come across this before and could maybe help - Its a new one to me! Customer recently altered layout of...
