B
B-I-L-L-Y
I have recently had my garden fully wired (radial system ... unsure that means) in each corner by a profession electrician. I have been informed that I can run electric heaters, kettle, etc. with no issue and it runs from the consumer unit in my garage which I think is connected to a 65 amp RCD fuse and he said if I wanted to run power to my new shed then I can merely spur off of one of the double sockets to a separate fused switch.
Ok so what I want to do is be able to move my shed in and out to maintain it every year so was thinking of using a one of those IP67 adapters like you see when connecting caravans to cars, so having a fixed socket on the fence and have a trailing flex from the shed. The trailing flex I was going to attach to the shed and then on to a new smaller consumer unit in the shed (x1 for lighting and x1 for plugs) ... does this sound ok?
I'm a competent diy-er just wanted to know the best (not necessarily the cheapest) way to do this and what parts to look out for, cheers for any advice?
If it is a radial circuit with sockets it is most likely on a 20a mcb protected by a 63a 30ma rcd from what your saying, in which case you won't need an fcu as the breaker is 20a
  • Creative
Reactions: 1 person
IMO, I think you should get back the spark and the do the job for you .to make the job wright.
  • Agree
Reactions: 1 person
Sounds like a winner to me. If you use one of those IP67 adaptors you could tow the shed down the road to get it maintained into the bargain.
Got to be a wind up.
  • Optimistic
Reactions: 1 person
I got to agree with westward this time.
Caravans to cars???? Not caravan to hook up?
upload_2018-5-14_22-29-49.png shed on wheels ,me thinks .
Or this?
A New Zealand version of a mobile home.
  • Funny
Reactions: 1 person
From External Socket to Shed
DIY Electrical Advice
Thread Tags
B-I-L-L-Y,
littlespark,
