Discuss Generator zs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
Frosty69
Hi people,
I am installing a three phase supply but the out building I am working in is currently fed by a generator and I cannot gain access to the main supply. I have 3 phase 40a type c mcb which in the niceic test sheets says max is 0.46 ohms. The zdb in the out building is 0.60 ohms and the zs of the circuit is 0.64 ohms which obviously exceeds the max zs. Can this be down to being fed from a generator? As I cannot see the main supply I do not know system or earthing arrangements for this site.
This is a large contract I have and this is the only site I have been on in london that has been a pain and the site says that as my permit is for the out building then I cannot access other parts of the site! I know details are a bit vague but any help would be appreciated
Reply to Generator zs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
I have a stand alone generator on site in a factory which will supply a machine rated at 900Amps. Do I need to common up N or E to the Main DB? I...
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
Cable calcs using cable calc app Working out cable size for a workshop. 100m long, 100a supply, mccb 100a zs- 0.23 ohms, in a duct on its own...
