H
harryfry
For a project at university I need a fairly intense light source for a fluid dynamics experiment, as the previous one broke. I've been advised a halogen source of around 50W should be sufficient, though as I am a mechanical engineer, my electronics understanding is very basic.
Through basic research I have found that a gy6.35 halogen source may be sufficient, and have found an appropriate bulb and bulb holder (see link), how would I go about wiring this so it is usable with a mains supply/some sort of source.
Thanks in advance,
Harry
[NOPARSE]http://sinolec.co.uk/en/low-voltage-halogen-lamp-holders/1211230-gx53-ceramic-lamp-holder-gy635-ceramic-lamp-holder.html?gclid=CM6qvtuqxsMCFasBwwodVzAAWw"]GX5.3 Ceramic Lamp Holder / GY6.35 Ceramic Lamp Holder[/NOPARSE]
That lamp holder is for ELV only (12VAC). You need a standard halogen lighting transformer 230-12v available at any B&Q or elec wholesaler.
Okay thanks. I've found some appropriate ones. Would I then need the holder that I have linked as well? And how would these all attach, ie. mains > transformer > bulb?
Cheers,
Harry
The pins on the halogen lamp should just push into the small holes in the ceramic holder. The 2 wires from the holder go to the 12v side of the transformer. The 230v side of the transformer will need a trailing lead making up with a plug on one end.
Keep your greasy fingers off the glass of the lamp by the way, use a napkin or piece of toilet tissue when handling the halogen. Obviously don't touch it when it's lit, they run at astronomical temperatures.
Halogen gy6.35 Light Source
DIY Electrical Advice
harryfry,
Marvo,
