Discuss Halogen to LED downlight replacement. in the UK Electrical Forum area at ElectriciansForums.net
Gakure
Hi all, I have been asked to quote to replace existing Halogen 12V with LED downlights.
Do you guys have any recommendation, there are 37 of them.
I have seen some at Scewfix for £89 park of 10 and kews they have H2 for approximate £12 + VAT.
*would you charge per light or on hourly rates.
are you replacing the cans, or fitting GU10s into existing?
the sizeof the holes in the ceilings may limit your choice. 70mm is the most popular size of hole for choice of fittings.
I initially planned to replace the cans including transformers with a new 240v LED fitting with driver.
I was also shown a conversion kit which I have to remove (unscrew) from existing.
Is there any insulation that you will need to contend with? I would only fit fire rated luminaires, even those LAP ones from Screwfix you suggested are.
nope. just that they're the best i've ever used.
Too touchy, must be getting a backhander. Can't blame ya, us pensioners - I've got a few years left yet (before that crisis) - need to supplement our income; booze is getting expensive these days. Not sure our 'special relationship' will help, their beer is crap.
Thanks guys really appreciate.
Regarding insulation-they are all on ground floor ceiling and as I could see there is none.
Holes - they are approximately 61mm.
I find that it pays to do a bit of a recce to see if the transformers are singles to each light, that they are accessible and there is enough cable to ensure the conversion - if all that works in your favour then quote for a lamp of their choice (or what’s in the van x number they need) and the GU10 lamp holder. Factor in the time to do them and you have a price per conversion.. a nice little earner sometimes and always excellent results. (Beats chasing walls or attic work which I’ve mostly been doing of late!)
I pulled a couple and i just have enough of cable.
Reply to Halogen to LED downlight replacement. in the UK Electrical Forum area at ElectriciansForums.net
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi all, I bought a house and went around replacing the mr16 halogen downlighters with LED lights. The lights are controlled by a Quinetic smart...
I'm homeowner and moved into a property which has 25 halogen downlights, I'm hoping to get an electrician to replace these with LED ones, what...
Hi I've just moved into a flat and it has old brass downlights in every room, I also think a lot of them are halogen and not led so keen to...
In the bathroom we have a panel above the wash basin with 3 x 12v Halogen downlighters powered through a single transformer. I am looking to...
