Discuss Help with Apprenticship work please in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
P
Pod17
Hi all, Im just doing some work for my level 2 JTL Portfolio and am stuck on the following two questions;
What are the common types, their advantages and limitations of wiring systems, wiring enclosures and equipment?
and...
How would you determine whether a wiring system, wiring enclosure and equipment for installation in a particular environment is suitable?
Any help would be appreciated as I am stuck with these :)
and...
what are the most common types you do at work do singles multicores armoured cable and put down what you think is the advantages for example cost for 1 and any disadvantages aswell also how would you deem them suitable for example you wouldnt use anything that would corrode such as galv conduit in an area with livestock like a milking parlour
my questions were a bit different to yours as i did mine with total people
and...
Common types of wiring system -
MICC cable, PVC/SWA cable, XLPE/SWA cable, PVC T&E cable, & Fire retardent cable.
Wiring enclosures-
PVC Trunking, Steel Trunking, PVC Conduit, Steel Conduit & Ducting.
You can do the advantages and disadvantages of the above but thats what they are asking
2nd Question IP Codes / IK Codes??
HTH
Matt
Reply to Help with Apprenticship work please in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi, Currently working my way through my NVQ portfolio (Nearing Completion) but getting stuck on how to complete the following criteria due to...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
having enrolled myself onto an electricians course at the end of jan, after deciding on a complete career change of baker/retail worker in the 25...
Hi all, hope you're well I'm hoping to find an electrician around Leicestershire/Northamptonshire that would be willing to allow me to come out...
