Discuss Help with Apprenticship work please in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
P
Pod17
Hi all, Im just doing some work for my level 2 JTL Portfolio and am stuck on the following two questions;
What are the common types, their advantages and limitations of wiring systems, wiring enclosures and equipment?
and...
How would you determine whether a wiring system, wiring enclosure and equipment for installation in a particular environment is suitable?
Any help would be appreciated as I am stuck with these :)
and...
what are the most common types you do at work do singles multicores armoured cable and put down what you think is the advantages for example cost for 1 and any disadvantages aswell also how would you deem them suitable for example you wouldnt use anything that would corrode such as galv conduit in an area with livestock like a milking parlour
my questions were a bit different to yours as i did mine with total people
and...
Common types of wiring system -
MICC cable, PVC/SWA cable, XLPE/SWA cable, PVC T&E cable, & Fire retardent cable.
Wiring enclosures-
PVC Trunking, Steel Trunking, PVC Conduit, Steel Conduit & Ducting.
You can do the advantages and disadvantages of the above but thats what they are asking
2nd Question IP Codes / IK Codes??
HTH
Matt
Reply to Help with Apprenticship work please in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi, Currently working my way through my NVQ portfolio (Nearing Completion) but getting stuck on how to complete the following criteria due to...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Good morning, We have a two-bedroom flat that my wife and I rent out to supplement our income. Following the recent EICR, several issues...
