Discuss Help with existing extractor fan in the UK Electrical Forum area at ElectriciansForums.net
Daz134
Hello
I'm. Swapping over a fan and need some help with the wiring.
Basically the new fan has
L1
L2
N
Please can you tell me which cable goes in which. I have attached the pic of the switch the existing fan and the wiring diagram
I understand the neutral but unsure which is the L1 or L2
Your help would be much appreciated
Thanks in advance
usually, L1 is perm L, and L2 is switched L. try them. if they wrong way round it just won't work, so then swap them over.
It looks like you have a 2 speed fan rather than a timer fan according to the wiring diagram you posted? It would not be a good idea to make L1 and L2 live at the same time if this is the case.
What is the model number of your new fan?
Hello
Thanks for the replies
Here are a few more images of the switch and the wiring diagram
Please can some one tell me which cables need to go in the l1 and l2 thanks
Daz... can you forward details of the make and model of the new fan. This is because your wiring diagram suggests that you have a 2 speed fan (min and max) but it would be more normal to have a permanent live and a switched live so that the fan over runs.
Hello. Thanks for the reply
Here is the box a showing the make and model
Ceritainly is a 2 speed model you need the Turbo-E T model for overrun timer version. This one can only be wired so it is either on all the time, or only on when the light is on.
Hi
I'm fine with it just coming on. When the light comes on and goes off when the light goes off.
Just don't know which cable goes where
In that case the green and yellow with brown tape (which is switched live for the old fan) goes to L2 for high speed, the brown goes in a separate connector block not connected to the fan to insulate it. Blue to N
Reply to Help with existing extractor fan in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
1964 house old style wiring Need to wire a extractor fan up Is it possible to wire the extractor fan to report switch there's 2 red wires in the...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
