J
Jlggomez
Hello everyone and thanks in advance!
So, I installed this LED fixture in my bathroom to replace an old fluorescent fixture that had a bad ballast:
www.1000bulbs.com
It is a dimmable (0-10V) fixture and it is working just fine with the original single pole switch that was in the wall. Obviously, not able to dim. I want to take advance of the fixture’s dimming capability, but am confused as to what type of switch to use. There is no low voltage wiring in the wall; only the original regular wiring that went to the old and replaced fluorescent fixture. I bought this dimmer switch, but it appears to need low voltage wiring for it to work as a dimmer:
www.1000bulbs.com
Is there a dimmer switch that I can use for the new LED fixture using the existing wiring in the box (two black, one ground)?
Any advice/tips would be very appreciated. Thanks for your help!
LG
32W, 4200 Lumen, 3 Colors, 4 ft. Selectable LED Strip Fixture, 3500K-4000K-5000K, 3 Lamp Fluorescent Equal, 120-277V, TCP TCPGPS4UZDA8CCT | 1000Bulbs.com
Reduce energy and maintenance costs by replacing fluorescent fixtures with this color selectable TCP LED strip light. Find more luminaires on 1000Bulbs.com!
Buy 010V LED Dimmer Switch Single Pole/3Way | 1000Bulbs | 1000Bulbs.com
Use the Enerlites 51300L dimmer switch with LED fixtures in all areas of your home and enjoy the light level you want. Find full range dimmers at 1000Bulbs.com!
LG
