Discuss Hi Folks in the The Welcome Forum area at ElectriciansForums.net
I have just stumbled over this forum and it is just what I was looking for, very informative, So here I am.
I started as an apprentice er.. hmm over thirty years ago now .
I set off wiring houses then moved into electrical maintenance in factories and for the last
eighteen years have worked offshore. I'm thinking of working less offshore in the future and perhaps picking up work doing EICRs back home near Manchester and would appreciate some advice.
I would also like to pick peoples brains about which is the best scheme to join , are there any standard charges for an EICR? and so on...........
cheers
Ian
you don't need to be in a scam to do eicr's, but some clients insist on it. as for pricing.. varies between !
£15 and £20 per circuit, or charge by the hour.your choice.
Welcome to the asylum mate.
Welcome aboard Locky69
It may be difficult for a competent electrician to survive doing pirs only
That corner of the market is notorious for questionable business practices
Charges can be a case of pluck a figure out of the air that can make it worthwhile, then hope you have it competitive
You could do the 40 mins per circuit and 40 mins per dist board and multiply by your hourly rate method
Welcome Ian ,
Change can get frustrating !
but resistance is futile.
50074
here is my new avatar. post assimilation.
50075
Thanks for the replys folks
Those sort of prices are fine for me . I have no interest in under cutting people and would only be looking to do a few jobs a week anyway.
How would you go about remedial work (not how to actually do it) but the paper work side . Am I right in thinking I would need to be in a part P scheme to issue an EIC . If so which one . Stroma appear to be the cheapest I think...?
No,as you know you issue a eic(or minor works) for all installation work
The Part P thing is for work that is notifiable under building regulations
For that you can inform and pay the council or you can become self certifying by joining a scheme
I'm with Napit but the schemes are all sort of the same burden,however as you say Stroma appear to be the cheapest
Reply to Hi Folks in the The Welcome Forum area at ElectriciansForums.net
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
Hi, I’m an industrial electrical engineer apprentice working at a wastewater treatment plant, I’ve been really enjoying the job which I’ve been...
Hi, I am involved in a local charity which is fundraising to restore a local pub into a community hub (and also a pub). The pub which is The Hop...
So far I have never had to deal with a new supply but a possible site we are looking at will need some major changes and so I wondered if folks...
