Discuss How does this bathroom fan work? in the UK Electrical Forum area at ElectriciansForums.net
Incredibly dumb question I’m afraid, but I’ve moved into a house and can’t figure out how to work the bathroom fan. Could somebody please help me?
Here’s the fan itself:
50139
And there’s also this (possibly unrelated) switch type contraption on the wall:
50140
This looks like it leads to two switches on the wall outside the bathroom (both control spotlights in the bathroom).
If anyone could help with this I would be hugely grateful
there might be a fan isolator in the attic.
50141
otherwise. can'thelp without phusically being there.
If there are no switches for the fan and the fan doesn't come on with the light the fan may not be working for some reason. It may also be a humidity operated fan, the small round aperture in the corner of the fan suggests this is possible.
Best to get a local electrician to have a look, that junction box on the wall does not inspire much confidence to the quality of the wiring.
Thanks everybody. The wiring in this house is sketchy at best and we will need an electrician in to redo it all. I’ll look around in the attic for an isolator but definitely feel like the first job is going to be a complete rewiring of the entire house :mad:
This might not be needed at all. Get a thorough inspection done first. This should take at least half a day to do properly (there are those that would pop in and out in an hour) This will give a good overview of the condition of everything.
It might be that you just need a few dodgy issues sorting and some repairs done.
A rewire entails considerable disruption and expense.
As above
Get a full EICR (electrical report) done
If the house is wired in modern twin and earth cable then it might just need tidying up and possibly a new consumers unit (fuse box)
If this is the case you are looking at hundreds where as a complete strip out and full re-wire you are looking at thousands ...
Reply to How does this bathroom fan work? in the UK Electrical Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
My extractor fan has given up the ghost this week and I was hoping to replace it myself, however I cannot do a like for like swap as the current...
I’m sure this is simple, but it’s confusing me for some reason. I have a line wire coming into a bathroom that used to go to a lighted medicine...
