Discuss How many holes can you put in a wall? in the UK Electrical Forum area at ElectriciansForums.net
Hiya!
Got a customer who wants me to install a cooker hood but it apparently requires a new hole for the venting as the existing one is too low down to utilise. I'm just pondering whether coring out another hole a foot or so above an existing one on a load bearing wall is a good idea structually. I assume it comes under part A but I can't find any information on how many holes you can put in a wall. Anyone have any thoughts?
I handled this situation by using adapters to the rectangular ducting to bring the vent higher and building the extractor slightly out on stud work.
It was a bit of a pain but looked ok and worked well.
Fill the old hole with concrete and rubble before coring new.😌
I thought most hoods are fairly standard for venting heights. How come the original is so low?
Reply to How many holes can you put in a wall? in the UK Electrical Forum area at ElectriciansForums.net
Since the deco needs doing to this property. My sister needs the TV putting on thr wall but wants the cables hiding. What will be the best way...
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
So I had a ceiling repair done in my bathroom due to water damage. The neighbors toilet above me was leaking for who knows how long. Mold...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
