Discuss How to install external wiring for AC ducts in the UK Electrical Forum area at ElectriciansForums.net
Hi all i am trying to install AC in my house but i want to supply the power directly from the main supply. but i don't know how to connect the AC breaker with my main switchboard.
Are you located in Burnley? Or using a VPN through Pakistan.
No idea on the rules in Pakistan, however a job like this in the UK needs to be undertaken by a competent electrician.
Hellengeek. with all due respect to you are you intending to do this work yourself, both Electrical and HVAC? because if the answer is yes then you face danger not only from the electrical issues, but also from the dangerous liquids and Gasses within the AC units.
Best advice is get the professionals in to do the work, I'm assuming you are not an Electrician or a HVAC engineer as there isn't any access to your profile, good luck with your project.
Reply to How to install external wiring for AC ducts in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Problems with wires - these wires power the air condition external unit. Last time I switched on it tripped my main ecb. Any suggestions on how to...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
