Discuss How to lan work two computer in the Computer and Networking Forum area at ElectriciansForums.net
I'll assume there is one computer already working, and you want to add another. So :
1) Does the first computer plug into a router via a LAN cable ?
2) Does the router have more than one LAN port on the back ?
If both are yes, then just plug the second computer into any of the spare LAN ports on the router and it should just work.
If 2 is no, then you'd need a switch to expand the single LAN port to "multiple". Connect the single LAN port on router to the switch, then each of the computers to other ports on the switch - then it should all just work.
If the answer to 1 is no, then more information needed.
Reply to How to lan work two computer in the Computer and Networking Forum area at ElectriciansForums.net
One client asking me to replace two one gang existing RJ45 data socket . One of them have to replaced with 4 gang and another one gang replace...
Hello How buzzer work it has transistor when i put transistor in buzzer it sound what transistor do
Hello everyone. What tool would I need if I were to work on a construction site doing containments? Thank you
Hello, I want to ask, I'm going to change the lights on a Skoda mk2 for a black version, I noticed that they only have one h7 bulb and a bixenon...
Hi, I am just wondering if there is anybody out there interested in allowing me to do a little voluntary work with your company to gain a little...
