Discuss How to wire a double switch in the UK Electrical Forum area at ElectriciansForums.net
Hi, I’m trying to wire a two way two switch into my lounge, i have a live feed coming from the consumer unit to the switch. I have a feed going to an external security light and also a external junction box for future garden lighting. I have wired the switch how I think it should be and it does work until I turn on the switch and then it trips, please advise on how to wire the double switch
Welcome to the forum mate.
Can you draw a diagram on how you have wired it.
Just draw it on a piece of paper, take a pic and upload it.
My fault, this is the one
diagram looks OK. you must have wired it wriong unless you have a short on one of the loads.
A couple have hinted at it, but to be clear the N cables SHULD NOT BE CONNECTED TO THE SWITCH
Just want to say thanks for the input, this has been driving me mad today.
so as a general consensus I should NOT put any neutral into any of section at the back of the switch, they need to b joined separately
The general consensus is, yes... you don’t connect a neutral to any part of the switch.... except one brand of switch that have now included a spare terminal marked loop, which is where the neutral goes.
just adds to any confusion.
Reply to How to wire a double switch in the UK Electrical Forum area at ElectriciansForums.net
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
