Discuss Identifying Asbestos. in the UK Electrical Forum area at ElectriciansForums.net
A
anfield84
Hi I was just wondering how one identify asbestos inside a wwall example old pplasterboard
apologies but I am new to this trade. Any help identify in asbestos wwould be appreciated
Hi Anfield84.
I've made your post into a new thread for you, the thread you tagged it on the end of was dormant for nearly 4 years.
Best bet is to go onto the HSE website and type in asbestos - there's loads of info, photos etc there. If working on/in a building, you can ask to see their Asbestos Register. They must have one and must show you - how accurate it is, is another question!
Read the information Polo1 has mentioned above and always remember that it is not possible to tell what is asbestos by looking at it (though some items are fairly clearly very likely to be asbestos).
In general you need to know the likely history of asbestos use and the age of installation of a suspect item, this information is rarely available.
If there are items that you have a good belief may be asbestos then analysis of a sample is the only way to categorically identify the type and so the remedial actions that may need to be taken.
Also remember that there is a lot of asbestos still about in many many places.
I agree with the replies in part, but remember that an asbestos register is probably only from a visual or a non-intrusive survey, that is one that does not look at anything that may be hidden and does not make any holes. The question infers that you are going into a stud wall or similar to run a cable? Depending on the age of the wall it may have asbestos as part of it, particularly if any fire protection may have been required. The client or organisation should have an intrusive survey done as part of the job but the recommendation to look at the HSE site for examples etc. is a good one as you never know what you may find and it could be lethal to you. If the building was put up in year 2000 or later then asbestos was banned and thus it should not have any in it. There are short courses to familiarise trades people with asbestos that many employers send their staff on (or have them in house) and some videos that are good to watch as well.
Some good advice being posted so far, from me if you think it's asbestos then treat the material as being asbestos, full relevant PPE precautions required.
Remember, you will not know if you have been exposed until possibly 10, 20 or 30yrs down the line.
Be safe always.
Firstly i would strongly recommend going on a asbestos day course. You only need the Cat B one really which isnt even a day long but very informative.
I would also say you should buy this book
HSE HSG210 Asbestos Essentials
Ive got a copy and keep it in the car. It goes into the principals of asbestos, the laws working with it, where it is commonly found (with pictures) and the remaining half of the book is broken down into activities and how to carry them out. For example, drilling AIB, removing floor tiles etc. Worth its weight in gold that book
What you never want to do is just ignore the stuff though. It can be fatal in rather horrible ways and not just to you working with it. If you're working with it in peoples homes, it will have an effect on them if not managed right. Plus if the HSE get wind of you working incorrectly with it they will have kittens and "i didn't know it was asbestos" is not an excuse!
Also, do not be afraid to turn down work based on having to work on the stuff. If you cant work on it safely, it isn't worth the money you may earn. Its nasty, nasty stuff!
Even before then, I agree otherwise with your post,
to add to the other comments from others, Asbestos can be in tiles in your bathroom, behind the flush box on your loo, and a lesser type but still potentially dangerous on garage roofs lol, it can be in all sorts of places but modern houses will be fine.
Just to add, it can be in early Artex too.
that would be the good old artex that smelt like cat pee, dried out white, and didn't need painting until you'd smoked your way through 500 packets of smokes.
And was used as glue to stick coving up,and as a fine filler before dry lining adhesive.:D
Made the dust sheets and work clothes smell like you said too.:icon11:
Reply to Identifying Asbestos. in the UK Electrical Forum area at ElectriciansForums.net
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
Morning I just wanted post this information for anyone that may come across these Storage Heaters as I have struggled to find any relevant...
My customer has just moved in and wants to make sure the electrics in the garage are safe. I have only carried out a pre-works visit so far and...
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Hi I’ve recently got my first home I’m not entirely sure when they were built I’m thinking possibly 60s or 70s? My problem is the storage heaters...
