Discuss Installing earth rod in the UK Electrical Forum area at ElectriciansForums.net
Just how hard could it be,to place it outside,in the same ground as if you have gone sideways,yet without the hilarious consequences?
Go big of go home. If you're going to run the risk of penetrating the tanking you may as well go whole hog and drill the floor and whack in a spike downwards. You're more likely to get a decent Ra reading on it and the repair bill for the waterproofing at a later date will be exactly the same ;)
Don't stick a twig in, whack a decent size rod straight through the floor and if needed screw another on top lol, these 3 ft 10 mm2 rods are a complete farce.
You channelling Eng54 there?!? I think the approved terminology is 3/8 twig, though... ;)
On a serious reply to you, I completely forgot about ENG, anyone here know what has happened to him?
I agree, a 10mm² rod gets pretty bendy. A 10mm dia rod is much better. ;)
Actually, if you check the research, the rod diameter makes little difference to the Ra. The length is much more important.
The point is the slightly thicker rods have the thread on the end, and it is easy to screw another on to it and go even deeper, these 3 ft things are pretty crap, obviously in good ground they will do the job, I never used them myself, but the ground around here does have a lot of stones in it and they just struggle and are pretty pointless.
Indeed. If you're going to hammer a rod into the ground, you might as well use something you can extend if necessary.
Haven't seen him around for a long time on any forums. Maybe Tony would know something.....
Reply to Installing earth rod in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Hi. The question is..... can saturated ground affect earth resistivity testing equipment? Some days there's an unacceptable earth reading, another...
I’m not working on this… not yet anyway, but can someone tell me why there’s a fuse or a link on the earth here? The green wire is bonded to...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
