Search the forum,
Discuss Is this 10mm? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I need some advice- I'm no electrician, i'm just wanting to know the cable size i have in existing shower- Had a look in attic above shower and have attached pics of the cables against a measure (starting at 10 cm/ tape was broken)
Can anyone confirm of these are 10mm or 6mm please?
Wanting to know what kw of shower my cable can carry si i can buy for the electrician to put in.
Many Thanks,
impossible to tell from that. get your electrician to confirm cable size before ordering shower.
Many Thanks,
10mm and 6 mm refers to the CSA of the L and N conductors NOT the overall dimension of the cable, what size in KW is you're shower?
He/she would more than likely have some cable in the Van
A lot of manufacturers emboss the cable sizes on the outer sheath, they can be difficult to see but wiping a dirty finger over them often helps.
Many Thanks,
If you are getting an electrician to put the new shower in then probably best to get them to come around first and take a look at the cable. The difference between 10mm and 6mm is pretty easy to tell just by looking at it. They could also peek inside the isolation switch as they could see the earth. On 10mm cable the earth has a number of strands to it. 6mm just has one solid core as it's earth.
Many Thanks,View attachment 65261
Thanks all for the replies.
The electrician is proper hard to get a hold of so was wanting to have the shower sitting waiting there ready to install all on one day.
There are some stamps on the cable/ looked the whole way but just gives the manufacturer and bs6004.
(I don't know why the size isn't just stamped on the cable)
Someone above said that it impossible to tell from the measurement- I did come across this (attached pic) online and the above measurement looks to be about 17mm ?
Posted above there again, but also some extra info: The Box shows the shower fuse as 'B40' if that helps any?
That's got to be 10mm hasn't it? Is there any 6mm twin and earth cable that has an earth like that? If so, I have never seen it before.
Is there any imperial cable that may look like that and be <10mm?
Reply to Is this 10mm? in the UK Electrical Forum area at ElectriciansForums.net
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi all, I was thinking to add some lights like in the attached image, basically twin batten lights to my attic but i'm not familiar with strip...
The ongoing kitchen refit..... I have chased and fitted 10mm T&E from the cooker outlet to the isolator switch and up into the loft. I have 4...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
