B
Baddegg
As per title, went to look at kitchen rewire this evening, no probs all straight forward, as I’m about to the leave lady says while you here I keep getting shocked from this wall when I washed it down?
Turns out someone has extended old 4 mm stranded cooker circuit with 2.5 and put a double socket on the end, but they decided to just twist the cable together and use a little insulation tape and left on a 32mcb....
Anyway what is people’s preferred method of jointing two different size cables?
Going to change the mcb but also curious as to which cable type id select if filling out a certificate?
Hope that all makes sense and as always thanks to all
