P
Piratepete
Hi Guys.
I've just replaced an old rewirable Wylex consumer unit in a house with all pvc/pvc T&E solid core aluminium cables. 2 rings on 30 Amp fuses, 2 lighting circuits on 5 amp etc. The cables were in good condition (at the box at least) so no probs. A couple of earth continuity probs to sort.
But, the core diameters seem to be identical (within 0.05mm) to copper cables; ie. the ring core lives are 2.5 sq mm and the earth is 1.5 sq mm. I expected larger to get the copper equivalent.
Does anyone know what the rating of these cables is. What alu wire sizes were used back in the 70's for sockets, lighting and cookers? What were their current capacities?
I don't have access to old regs (early 15th?) to check.
Pete
Pete
