Discuss Just curious in the UK Electrical Forum area at ElectriciansForums.net
I come across a fuse spur today taken off the ring main used for a outside light but the spur was fused at 13A shouldn’t it be 3-5A instead ? I changed it to a 5 because in my eyes it made sense
Could it be because fused spurs are supplied fitted with a 13A fuse and some people CBA changing it for a lower value fuse to suit the load
Like Dave OCD , I probably have several 100 13a plugtop fuses at the bottom of my bag
What on earth do we do with all these 13a fuses ? land fill ?
Reply to Just curious in the UK Electrical Forum area at ElectriciansForums.net
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Im just curious as to peoples thoughts on the following install I seen on a video from an Electrical firm today and they did the following: Ran...
I've had a search, and found an old thread from 2016... but was wondering about modern views on this situation. I've come into possession of...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Can I supply my central heating (programmer, two port valves and boiler) via a fused spur taken from the immersion heater circuit? They’re...
