Interesting thread, this one.
I have a garage/store to put new lighting circuit in. I was put off some of the battens due to the end-to-end connectors and lack of CPC continuity provision, also I would really prefer a batten with a rear entry option to loop in and out, so if anyone can suggest such a model I would be grateful. I have 2 options:
1. Use the existing metal conduit, which has fairly recent cabling at each of the 4 light fittings, and attach battens via the current round fittings, drilling the back of the battens to suit so I can bolt to the boxes
2. Run a completely new lighting circuit and make-up mounting points for the new battens to fix them to the steel beams that the old conduit is fixed to.
This isn't a big project, so cost is not really an issue.
I'm considering using QuikWire connectors to make it easy, and to avoid daisy-chaining the fittings. I've used them before and they worked fine. This would be more of a "spider" installation, but would bring the CPC to each light fitting (there will only be 4 of them) and if nowhere to park the CPC I could simply bring the CPC into the batten body and terminate it in a 2 way Wago with the option to carry on to any extra battens if required.
Alternatively, I can daisy-chain with the QuikWires, carrying the CPC from point to point...I haven't really decide yet.
Thus, i suppose my question is, what battens will let me use rear entry positions so i can fis as required and carry CPC all the way? What I want to avoid is those awful "plug together, end to end" fittings with no CPC provision.
