Discuss LED ceiling lights - I'm baffled in the UK Electrical Forum area at ElectriciansForums.net
The customer has five small LED ceiling lights in their bathroom. Some of the lights stopped working. A previous electrician came and 'did some work' but could not resolve the matter. I've taken a look, and three lights have been removed. I assume these were the broken ones, and he took them to go and match a replacement. Two sre still functioning but are stuck and unable to be pulled out.
What is confusing me is where the lights have been removed; this is what the wiring looks like:
Can anyone help me understand what the **** is going on here? How could there possibly have been a functional LED light here if the neutral has never been tapped on one and is linked with live on the other?
I just did a flying visit as ladders are required to access so going off of visuals.
So this is the issue, the customer has no idea where the transformer is.
I'd get the old ones out, if they are only 40mm and they are truly stuck then you can work out where the joists are and drill out for larger replacements. (preferably 230v)
If one of the feeds doesn't end up pulling a transformer or mains supply cable within range, you can send up a camera and I normally start guessing where a ceiling rose probably was once.
Most are fitted appallingly and the transformer will be flapping around.
Reply to LED ceiling lights - I'm baffled in the UK Electrical Forum area at ElectriciansForums.net
I bought a ceiling fan with LED lights. After some time the led lights started flashing when I put them on. Now it does not even jump up anymore...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
Hello, I've installed a Monsoon Extractor Fan kit today, all is up and running and everything is working with the exception of the LED. When I...
I am installing 9 LED downlights each with an RGB bulb in (i will try attach pictures on them) - anyway I have been told that they need to be...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
